This command globally enables or disables Convergence End Point (CEP) for ONEPolicy.
| enable | Enables CEP for ONEPolicy. |
| disable | Disables CEP for ONEPolicy. |
By default CEP is disabled.
This feature requires that ONEPolicy is enabled on the switch (see enable policy).
The following example enables CEP on the switch:
# configure policy convergence-endpoint enable
This command was first available in ExtremeXOS 22.2.
